Re: need to clean carb
Those carbs are very easy to clean, I think that might have the integrated fuel pump, if so you might want to disassemble it before you go and start spraying carb cleaner in it. Carb cleaner will kill any rubber diaphrams it touches. Since you have it apart you should go ahead and rebuild the fuel pump too. Every merc integrated cab/fuel pump that I rebuild I do both, it only costs a little more, but if one needs it chances are they both need it. A good manual will have step by step procedures for both.
