need to idle up motor
Dusty279
76 Evinrude 85 hp....need to tweek the idle up a little. where's the adjustment screw?
Thanks
Boss Hawg
Re: need to idle up motor
Should be two large horozontal SS screws just behind linkage -
Be the one on bottom for idle :)
Thats about as technical as i get :D
Dhadley
There should be only one screw thru the throttle arm, about in the middle of the arm. If everything is right that screw should be about in the middle. If it's screwed in more than about halfway, something is wrong. If you move the screw, recheck the sync-n-link.
