Need to know if I have a genII 4.3 or not
silvert
Here's the deal, I bought my boat a year ago in pieces. It had a cracked 4.3 some one dug into but gave up. I built a new short block myself, used a different block but rebuilt the factory heads, and installed myself (new boat owner at the time, knew nothing about boats). The boat is a 95 Maxum 2000sr w/4.3LX, 4bbl carb. The heads are the "vortec" heads with the plastic valve covers. Unfortunately I scrapped the original block so I don't have a serial number off it....yeah....dumb mistake I'm finding out lol. Anyways, I'm due for new spark plugs. I've seen where there are 2 options for '95, (at least in my research.) One is a "genII 4.3", which uses a plug with more threads, and a 4.3 that calls for a different plug with less threads. I've been using the ngk BR6FS, which is the plug with the shorter amount of threads. The other option is the NGK BRP6EFS, which has more threads. Unfortunately I didn't check the plug fitment with the heads before I installed them on the short block.
Obviously the BRP6EFS could possibly cause damage with it's longer reach but I could be losing performance with the BR6FS. Is the GENII 4.3 the one with the vortec heads? TIA for the help!
achris
More fish than mountain goat
Re: Need to know if I have a genII 4.3 or not
Easiest way to tell is the bolts that hold the intake to the heads.
If you have 8 bolts that go straight up and down, then you have Vortec, and need the BPR6EFS. If you have 12 bolts that go in at an angle (more perpendicular with the head than the block), then you have non-Vortec heads, and need the BR6FS plugs....
4.3 Gen II had non-Vortec heads. The 4.3 Gen+ was the first with the Vortec heads....
Don't get the engine 'gen II' (which is unique to the 4.3) confused with the drive 'gen II'....
Chris....
silvert
Thanks for the reply. Just checked, I have 12 bolts holding the intake on. The valve covers are the center bolt ones that say vortec on them. So, the br6fs plugs are correct....correct?
achris
Correct....
(those plastic covers with 'Vortec' on them don't mean these V6s are Vortec engines, it's just a word on the cover; that confused the beans out of everybody when they came out :facepalm:.)
Chris........
silvert
Thanks for the replies!
