Need to know year of 75 HP Chrysler
eddy622611
I just bought a pontoon boat with 75 HP Chrysler. Model #757HA Serial #9766 The engine seams to start and run fine with muffs. I have not had it in the water yet. Could someone tell me what year it is and what spark plugs that I should run?
Thanks Eddy622611
eurolarva
Re: Need to know year of 75 HP Chrysler
Production years for that motor were 1974 and 1975. Spark plug spec shows an L20V champion Plug
eddy622611
Thanks eurolarva. I will buy a set today. The boat came with a new set and they were differant than the ones in the motor
eddy622611
eddy622611
Went to the auto parts store for Champion L20V. They didn't have any, but he cross referenced to an Autolite 2852. Are these OK ?
Thanks,eddy622611
eurolarva
I cant say cause I am not a spark plug guy. Specs seem pretty similar though This is a the L20V
Racing Plug, 14mm Thread, 12.7mm (1/2") Reach, 13/16" (20.6mm) Hex Size, Gasket Seat, Non-Resistor, Surface Gap
This is the 2852
14mm Thread, 12.7mm (1/2") Reach, 13/16" (20.6mm) Hex Size, Gasket Seat, Non-Resistor, Copper Core, Surface Gap
Here is the L20 V
Champion surface gap V plugs have a .050"annular configuration with no ground electrode. Engineered for extremely cold application, the firing tip is nearly impervious to pre-ignition, however, fouling deposits can be problematic. These plugs have extremely limited use in racing and require a special high energy ignition system and a very rapid rise time(CD). Constructed with a nickel shell for faster heat dissipation and copper core or double copper (when noted) for further heat removal, all racing plugs are non resistor (unless specially noted).
And here is the 2852
Autolite spark plugs are engineered for every type of internal combustion engine. Copper core aids in cooling and improves resistance to fouling. Surface gap plugs have no ground electrode attached to the steel shell to project toward the center electrode. Rather the outside steel shell itself acts as the ground, removing all chance of plug induced pre-ignition. For use with capacitor discharged ignition systems only(CDI).
Chanan
Need to know year of 70hp chrysler
model 707hd ser#5141
thanks
Robert
oswald
The 707HD is 1971 year production
oswald
