bktheking
- Joined
- Jul 29, 2008
- 5,057
Re: Need to pull carburetor 1988 9.9 Johnson
I imagine the nozzle is for the high speed feed of the carb but I might be wrong. The starer has to come apart- loosen the bolt and remove the starter. Carefully let the tension back itself off. Pull the plastic part with the teeth off, you will be left with the cup, spring and washer. Put grease on the washer to help it stay in place. Put the top tooth plastic piece back in where it alignes with the slot on the spring and put tension back on the way it came off and bolt it back up. Take note on the direction the spring tension is before you start. Do this slowly, you don't want that spring to come out, they are a PITA to recoil and may take out your eye if it jumps out uncontrolled.
