Need to replace outer transom board
guy48065
First of all... I assume this plate has a name but I couldn't find it.
Anyways mine is crumbling so I drilled out the 4 rivets holding it to the inner transom board (itself in good condition) and removed it to use as a template. It's a scant ¼" thick so I want to replace it with a thicker piece. Considering using ordinary 11/32" (9mm) bcx plywood. Is that acceptable for infrequent use? Should I consider pvc trim board?
This is on a 12-foot aluminum boat that only gets about 4hrs use each year.IMG_20230729_144331.jpg
silverbul
I'm sure plywood would be fine, 11/32" (9mm) bcx plywood would be good.
It's a scuff plate for outboards that get removed frequently.
I would get a piece of 1/4" white oak plywood
airshot
We used to refer to them as a clamp board in the old days. Outboards had a couple small little feet on the transom clamp that would bite into the wood to keep the motor from slipping off the transom. Easy to replace fairly often...
guy48065
Yeah I assumed it was intended to a sacrificial part because of the ridiculously thin plywood that was used but it would have been better had they used bolts instead of rivets to attach it.
I've seen a lot of really ugly attempts to repair or replace this piece over the years. Hopefully I can do better.
And Scott I get where you're coming from with the white oak suggestion but I've never seen oak exterior-rated plywood. I'd be concerned it would quickly delaminate into decay-resistant-oak layers.
White oak is rot resistant. Old timers wood preservative and spar varnish will keep it preserved
