Sea Rider
- Joined
- Sep 20, 2008
- 12,345
Osageinmt,
Glad to read that you're on the right track to boating perfection. You need to dial a transom shim height that when alone at close tight turns prop doesn't aerate. Know that pulling head out transom to check water flow passing by lower leg can be intimidating, includind dropping cameras, cel phones into the blue, could ask another boater to ride side to your transom and check lower leg condition.
Check with you alone same as on your last outing new 10 pitch prop, that will surely put you on the max 5500 wot rpm with good top speed, wot rpm will drop accordingly when extra family members are added. Would you say you have achieved an increment of around + 500 rpm while boating with you alone and lightly loaded when passing from 12 to 11 pitch ?
Post final results with 10 pitch, that's you alone and then with family members added to check rpm difference under both modalities. Just for the record.. This is the sweet engine/transom height example I like using, try to dial same and boat happily forever under all water cond.
https://www.youtube.com/watch?v=oBeZjaA76VM
Happy Boating
Happy Boating
