Need trim and limit switch routing diagram where wires are routed in gimbal housing
tank1949
I have not been able to find how to route wires inside the MC alpha 1 gen II gimbal housing. I installed new switches and know how wires pass through top part of housing ans secured with two compressed halves, but do wires route behind 3/4" water hose or what? Do they require tie wraps to secure them to any billows/hoses? If anyone can provide diagram, please do so. thx!!!!!
tpenfield
Re: Need trim and limit switch routing diagram where wires are routed in gimbal housi
They should route pretty much straight upward towards the back of the engine. No need to wrap it around the water intake hose, etc.
you should also see the mating connectors in the area of the back of the engine . . .
??? Did you take the old switch wiring off, and if so, do you recall how it was connected?
