cyclops222
- Joined
- Mar 21, 2024
- 3,142
I am looking at the bright side of my life. I will only get old and near death 1 time.
sorry to hear about poor health... .. just keep on boating and fishing !I am looking at the bright side of my life. I will only get old and near death 1 time.![]()
is it getting to full power? id think you'd get some fuel on your hand at higher RPM but if its wet that don't sound right to meChanged thermostat and have quick hot idle temperature.
But when I did a quick palm of hand over the carburetor opening at idle speed. Fully wet gasoline coated hand............. Looks like Reed Valve blocks next. Oh well. Somebody is going to get a Sweetheart Oldie.![]()
Well you remembered that you forgot so you still in the game.Thank you flashback. Since my only problem is now just the slowest speeds. I will do my first tank of Seafoam cleaner in the fuel tanks. I have forgotten to do that this spring.
" Old people can only remember to forget. " Famous Cyclops saying.
After the Sea Foam cleaner is put in both tanks. I will then put in the STANDARD heat range NGK sparkplugs to see if the engine is now running OK. On everything but idle speeds.
There are far Better Snake Oils than Seafoam, to put in the Gas in an attempt to remove Gum-Varnish. Merc PowerTune, or BRP Engine Cleaner. The risk of using any Cleaner in the Fuel System, is it will dislodge a clump of Gum/Varnish but not dissolve it, and that clump goes on to really plug up a Fuel Circuit, which, in a 2 stroke, results in a lack of LubricationThank you flashback. Since my only problem is now just the slowest speeds. I will do my first tank of Seafoam cleaner in the fuel tanks. I have forgotten to do that this spring.
The Timing is what determines the Idle Speed on that Engine, so Your Mechanic can't just retard it unless it is to lower the Idle Speed. It is not like on an Auto where the Idle Speed is set by the Carb Opening.Surprise !! I just remembered a possible cause of idle speed sparkplug fouling reason. I asked the mechanic to RETARD the timing at idle. To prevent the engine from RIPPING the rope and wood handle out of my hand. Had a lawn mower severely bash my hand with a kick back. We did not specify any amount of idle retarded timing degree. I can start the motor with 1 or 2 pulls.
Is Idle timing easy to adjust with a timing light ?
