Needing to prime before every start.
JoshOnt
Today when I was out boating I noticed after a bit of tubing and racing around that if I shut the motor off to change tubers that I would need to prime the motor before restarting the motor. It had not done this up until to day. Motor is a 1977 mercury 50 hp My only idea was fuel pump but I am not mechanically inclined so it might be way off.
ondarvr
When you say prime, do you mean squeeze the primer bulb in the fuel line, or hit the primer button to richen the fuel mix. The fuel pump wouldn't have anything to do with it, it only functions when the motor is running.
Ike-110722
If you mean the primer bulb it sounds like a vacuum leak in the bulb or fuel line. How long has it been since you replace the bulb an fuel line?
MTboatguy
There is probably a small air leak in the fuel line somewhere, I ended up replacing my complete fuel line with new bulb a couple of weeks ago and have not had this problem since.
your basic starting point on that motor would be to slowy squeeze the bulb and make sure its firm ,then take off your front motor cover ,hood band and the top cover .look from the rh side (starter side ) and look at the carbs on the rh side of each one and check for fuel leaking at the carbs where your fuel or fuel lines hook up to the carbs ,while gently squeezing the primer bulb .I cant remember if yours has the little plastic covers (usually blue plastic ) on the fuel inlet side of each carb a very notorious area for leaks any fuel leaks or a faulty oring in your fuel connector in the front of the motor these motors are crazier than a diesel any fuel leaks or air intruision they will not start or run very well ...............the big heavy merc fuel connectors are hard on sealing points where they connect to the tank and the motor
