Needs a squirt of fuel to start.
lana-n-me
1979 150hp. Merc. Requires a squirt of fuel directly into the throat of the carb. Choke is working properly.
Laddies
Banned
Re: Needs a squirt of fuel to start.
Is the gasket between the choke plate and the carb bodies leaking or the float levels make be low,
lana-n-me
Float level is not low. Could be leaking between carb body and choke plate. There is a lot of fuel/oil residue on front of motor.
Plainsman
If you keep priming the bulb, does fuel leak out of the carbs?
lana-n-me
No not a bit. I have tried to hold steady firm pressure to detect seepage and it firms up solid.
