asianstars
- Joined
- Jun 6, 2009
- 3
1st time boat owner needs some helps.... Just test run the boat with 2 persons onboard and found boat did not have enough speed with high RPM. The engine is making high RPM, but not pushing hard enough. Read several article about changing to higher pitch or increase diameter of the prop. What is the ideal prop size to maximize the engine size?
Current prop is a 3 blades AL with a marking of 10x13
The engine is 1997 Evinrude 25 E25ELEUB 2 strokes. Per spec., gear ratio is 2.15:1, Min WOT RPM 4500 and Max WOT RPM 5500
My boat is a 1997 Carolina Skiff J16 flat bottom fishing boat.
Hope to get some help on a ideal prop size that can give the engine a optimal push. Thanks!
