Needs some information about a Johnson 10hp QD-18
cajuncook1
Hey guys, got my eye on a 1957 10hp Johnson QD-18. Been reading some of the more recent and past post on these series of motors. A lot good information supplied.
My biggest concern is compression numbers for this series.
What is consider excellent, good, ok, and no way?
The reason I like to ask you guys is because is because not all motors are the same and compression values vary with series and hp of motor.
Example: compression for the 9.5hp Sportwin series because of the low impact starter is 60 to 80's compression is considered ok to good.(that is my general understanding)
Any suggestions about compression numbers for QD-18 or any other advice would be awesome to get.
Appreciate any suggestion guys!
cajuncook1
Re: Needs some information about a Johnson 10hp QD-18
bump
1946Zephyr
I think about the same would be good for the old QD-18 What's more important, is that the compression readings are within 10% of each other. I found it's best to take a compression test, once the motor has been running, that way the rings are all free and working the way they should be.
cajuncook1
Thanks 1946Zephyr,
Appreciate your input, but it looks like I will have to continue my search for 10hp motor. The guy wanted $250 for a motor that is not currently running, stated ran 10 years ago, compression about 75/75, tank(says its ok), and motor is in ok cosmetic condition. He stated when they ran it years ago, they ran it on 32:1 fuel ratio(should be 24:1). He was firm on the price, so my search continues.
Again appreciate your input 1946Zephyr:)
kbait
The most I'd pay for what you described is $125, and that'd be after I confirmed that the fuel primer on the tank was functional. You're likely looking at coils, points/condensers, carb kit, impeller.. possibly gearcase seals, prop hub may be weak, clutch dog may want to slip.. etc. You could be looking at quite a bit of money and TIME that could be spent fishing! If I found the motor you're looking at in demonstrated perfect running order, $300, maybe $400 w/tank.
75/75 should be good. You can get different readings depending on how fast you spin it over..
cajuncook1
Pretty much what I was thinking KBait. I offered him max $150 if the coils were good and I didn't even want the tank, but I guess he wanted more...oh well, I told him to call me if he reconsidered.
Thanks for the information about the compression, I wasn't sure if that was low. Like I stated earlier, different motors, years and series have different compression requirements and I certainly don't know them all, so I usually ask to get some type confirmation or at least a consensus from a group of knowledgeable guys like you all.
Thanks again for your input Kbait.....appreciate ya dude!!
1946Zephyr
Well, 32:1 isn't a bad thing for the old QD-18, eventhough it calls for 24:1 It sounds like the pistons and rings are in okay condition, since the compression is even. 75 psi on both isn't too bad. It should be in decent shape inside. These motors are fully jeweled, so no worries on the crank and rod assemblies. Many people are out there running these at 50:1 without issues, but if they should overheat the slightest bit, the pistons have a risk of scoring.
For $250 though, I would want it running and ready to hit the water. I sell then for this price in top notch running condition and the buyer doesn't need to do anything to them, except rutine maintenance.
samo_ott
75# a side is about the minimum I'd want. and for a QD18 untested I would not pay over $75 with the tank up here.
And the QD18 is not fully jewelled as seen in the attached photo so don't go too lean on the oil...
cajuncook1
Thanks Sam_Ott and 1946Zephyr for further insight and information. I agree $250 is too much. Maybe I will email the owner in about a month and see if he wishes to reconsider a lower price. Unfortunately, the older motors are harder to find in my neck of the woods.
Thanks!!!
1946Zephyr
Well.....with the exception of the wrist pin, which is all the better. The main thing is, the crank and rod bearings are. At least with the wrist pins being the old bushing type, you don't have the issue of needle bearings comin out and bouncing around in your crank case, like a lot of them have.:D:D
I love the looks of mangled metal. No two particles look the same.:D
F_R
See, the problem is, the 10hp motors, pre-1961 are notorious for beating the wrist pins loose in the pistons. 1961-63 got the same wrist pin roller bearings as the big motors. For the older ones, I think they need all the help (oil) they can get. And I'm not so sure even that will help.
FHB
Mine gets about 70 on the compression test. I paid $75 for mine and have about $200 in it. The tank is important as the new tanks don't work.
Frank
