I have a 1997 evinrude 115 with a remanufactured powerhead. E115eleua, with the new block I got a new fuel pump, spark plugs, water pump, and rebuilt carbs. Upper linkage is adjusted correctly. And just a hint nothing has been touched or adjusted since I got the new block. From the first run in late march til currently the idle rpms in neutral have decreased over time. It's set(according to the shop who did the work) at 1000 roughly, maybe a little less, in neutral, right now it's only hitting about 600. Both ignition coils were replaced too. Any ideas? Compression 120 on all 4 cylinders
