Neutral interlock switch Force 120 adjustment
brianvolt7
Hey all,
I am looking for the procedure to adjust the neutral interlock switch on my 1990 Force 120. Any help would be great!
jerryjerry05
Re: Neutral interlock switch Force 120 adjustment
Disconect the cables at the connectors.
Find neutral,drive and shifter.Then adjust the cables and reconnect the ends.A bit of tension is needed on the throttle.
Then adjust the neutral safety switch till the cam hits the button dead center.
brianvolt7
If I understand correctly, in neutral the button should be depressed?
