Neutral wont engage. On vacation please help.
Primo321
1969 mercruiser 3.0 140hp.
Out here in the beautiful upstate ny thousand island region and my engine and out drive are being stubborn to engage neutral.
If I leave in the neutral position it eventually engages sometimes seconds sometimes minutes sometimes not at all.
What should I be looking for in a faulty linkage or shift plate?
I need this vacation !!!
Thanks
B
Re: Neutral wont engage. On vacation please help.
I'm not going to pretend I'm an expert with this but I had a similar problem which turned out was due to the shift cables. As a temporary "fix" I could get the drive into neutral by moving the shift lever slightly into the reverse position then back into neutral.
86 century
Ensign
Does that model have the shift interrupter set up.
If so I would say it has failed.
Try shutting the eng off and see if it will come out of gear.
Primo321
Sticks in gear when I cut the engine. Then has extremely hard time starting since it is the wrong position. Any do it yourself threads on adjustment?
Don S
May be nothing more than a binding/stiff shift cable from the control to the engine.
