ShaneCarroll
Thread starter- Joined
- Feb 10, 2009
- 639
Ok, so I replaced the outdrive today. Got the new one on, and got it all hooked up. Hooked it up to the muffs for a test run, the boat has not been run for two months. It was a little slow to start, but it finally started and purred like a kitten.
The Good News: I FINALLY HAVE FORWARD AND REVERSE!!!
The Bad News: I tightened the outdrive as tight as I felt comfortable (the 6 main bolts), without stripping the bolts. On the port side, by where the water passage o-ring is, there is a small water leak shooting out right there. It is very small, about the size of a pinhole in a water balloon (bad comparison, I know). There is also one on the top port side, spitting some water out as well.
My question is this: I replaced the gasket, and the o-rings. Everything is lined up, the gasket fits perfectly, the o-ring is in there for the water. Should I just tighten the bolts more, is there something I am missing, or do you put silicone or some kind of sealant around there?
