Hi folks, new user here and brand new boat owner.
Purchased a 2001 Bayliner Capri recently with a 4.3 Mercruiser. We took it out once and it did pretty well, but here is what I am dealing with. Hoping to find some help here.
1. Echoing dry bearing sound - FIXED by replacing the bad gimble bearing.
2. Minor backfiring at higher RPMs (maybe lower RPMs), but only heard them when prop came out of water a couple times. Is this due to instantaneous load loss or is there a real issue? My plan of attach was to replace plugs just in case and also to time the ignition. I've also wondered about the timing advance... Thoughts?
3. I understand that there is a special timing procedure. I have a timing light, but where can I find details on this "special" procedure?
4. I pulled out AC Delco R44T plugs, but the cover on the spark arrestor states AC-MR43LTS. However, the MR plug threads were MUCH deeper than the R44Ts that I pulled out. I was concerned that piston clearance would become an issue.
5. I've tried to find the engine S/N on the engine, but it is not on the spark arrestor cover, nor on the side of the bell housing (unless I missed it). Any other place that I could find the engine S/N?
6. Lastly, would anyone be able to confirm which engine I am dealing with on the Mercury parts list (pic below):
Thanks in advance for any assistance!
