Kola16
- Joined
- Jun 23, 2019
- 179
Hello all! I originally started with a Mercruiser 228 with FWC, but am upgrading to a built 383 stroker. I am upgrading my exhaust manifolds to center rise manifolds. I have the old log-style manifolds that has the alternator bracket mounted to the port side manifold. Is there a bracket I can buy that can mount the alternator in another low place? I see there are brackets that mount the alternator using the lower threads on the port side of the engine, but I do not know how well those will work since that is where the power steering pump bracket is mounted. I would think if I used the same holes as the power steering pump bracket for the alternator bracket also, the alternator pulley wheel would not align properly with the water pump pulley. Unless there is a bracket I am unaware of.
I have also seen brackets that mount the alternator on the port side head, but that is where the heat exchanger is mounted (not pictured).
I guess I am asking what is the typical solution for this? I know it has been done before from forums I have seen, but all the links to the solution are expired. Should I just move my heat exchanger and mount the alternator on the head? Move my power steering pump somewhere? I prefer just having 2 belts versus 3.
