New Battery and Switchbox Woes
andy6374
I've been told in the past that a brand new battery has the possibility of frying a switchbox. This actually happened to me 2 seasons ago. The engine ran, but it was time for new batteries. Put in two new batteries, and one of the switchboxes died. Replaced it and was good to go. I just got a new battery and I'm afraid to use it. Could I just ground the new battery for a second or two and get the "initial charge" off the battery?<br /><br />-thanks<br />andy
Re: New Battery and Switchbox Woes
Andy, I believe that is untrue. I have installed many batteries in my boat over the twenty-plus years I have owned it. I still use the original switchbox.<br /><br />I am assuming you are connecting the two batteries together in parallel (12Volts) rather than series (24 volts).
andy6374
Yep in parallel. It just may be a coincidence. However, a local reputable mechanic has told me he has seen plenty of switchboxes get blown by new batteries. Maybe coincidence, maybe improper hookup of batteries...nevertheless it has happened to me.<br /><br />Thinking about the wiring of the system it doesn't make sense that a new battery would do that. The only voltage the switchboxes get is from the stator. Unless your key switch is damaged and in that case a surge of voltage goes through the wiring that feeds the merc switch (possibility???)<br /><br />Who knows... I guess I will just get over it. <br /><br />-thanks<br />andy
Laddies
Banned
Andy, if your engine has alternator driven CD ign. the battery has nothing to do with the ign, system and will not effect it unless it has a bad ign. switch, just as Chris has said
andy6374
Yep, i wasn't disagreeing with Chris. Just throwing out what I've seen and heard. <br /><br />Like I also said though, it shouldn't have an effect. Thanks for the reaasurance though Laddies.<br /><br />-andy
DHPMARINE
I haven't ever blown a switch box by installing a new battery.But to take it a step further,I've replaced many switch boxes in boats with loose battery terminals.Damn those wing nuts !<br /><br />Just suppose the boat won't start.Cranks slow so Doug leaves the key on,buys a new battery and installs it (with the key on).<br /><br />I can see it happening.<br /><br />DHP
