new boat and engine - Shetland 535 & Johnson 30 HP twin stroke outboard -
Dewi
everything in my favor is going against me
I have been through the lists looking for my engine - a Johnson two stroke numbered BJ30BALCO
The closest I can find to the number is 1998 BJ30BALECS
can anyone help me out here please as need a starter motor fitting - I believe there is a place to mount it
thank you
Dewi
nwcove
Re: new boat and engine - Shetland 535 & Johnson 30 HP twin stroke outboard -
its a 1985, made in belgium.
Dewi
thank you very much - but how do I get either a parts manual or spares if it not listed on boats.net etc
30HP
J30ECOA
J30ELCOA
J30RCOA
J30RLCOA
J30TECOA
J30TELCOA
these are all that are listed
thank you
Dewi
thank you very much indeed sir
Dewi
item 28 on the pic below this is wired to somewhere beneath the flywheel
shouldn't this socket supply the battery??
the bloke that had the boat before me used to recharge the battery every time he took the boat out
I am sure another engine I had the battery was fed from this socket
but I cannot find a rectifier anywhere - so perhaps that's why he didn't use it - advice please
thanking you
Haffiman
That socket is only on the manual start engines and may be used for nav lights only. If you want to charge a battery, you need to buy #6, rectifier as well. Cut the wires to the socket and connect to the rectifier (follow colors). The red from rectifier to battery and a separate ground from battery to engine ground.
Dewi
Thank you very much for that - Dewi
