Hi all
I just picked up a boat and motor combo with a 70 hp Evinrude. Could someone be kind enough to confirm the year of the motor? The model number is 70673D.
Is there anything particular I should know about this model of Evinrude? Is there a "tell tale" for the cooling water? I assume the fuel mix is 50:1, correct? Any common problems or failure points with this motor? The compression was tested at 130, 130 and 140 and the motor looks very clean.
Here in Canada it's time to put the boats away very soon, I hope to use the boat once or twice and then winterize it and hopefully have a pretty solid boat for next summer.
Thanks in advance for your help,
Marc.
Marc.
