new boat with some problems
firehog6305
Hello guys I just picked up a boat that has twin chev305 motors with omc outdrives, the boat has been stored for 10yrs, I did the standard stuff of changing oils and fuel, and lubed the clyinders before starting, motors and outdrives work fine *thank god* The problems I have are stupid, and I thought I need a fresh idea on which way to go, before spending a lot of money, on one motor I have no power to the gauges, the one motor that I have power to the gauges has two 12volt batteries in line, I guess that its a 24volt system? the motor that doesnt have power to the gauges only has one large 12volt truck battery, do you think the reason why I'm not getting power to the gauges, is that I need 24volts on that side? it has a perko switch and with the switch on both, I still dont have power, everything is hooked up. The other problem I'm having is that, the motor that I have power to the gauges wont start by the key, I jump the siloniod and starts up fine, I know those old OMC's (1978) have a poisioneer switch on them, I looked at it and parts are missing, Can I just remove that to make it start?? any advice will help....Thanks:)
lilmandavis
Re: new boat with some problems
Well bypassing the neutral saftey switch is always a good idea. Especially when someone is on the back and you start it and....Its in gear. You need a manual and a voltmeter. I'd start with some simple voltage tests and the right parts before anything. Especially with 24 volts on a sbc. Id bet the starter is getting red hot and the voltmeter is pegged out when power is present.
firehog6305
Thank for the info, I know removing the saftey switch is dangerous to say the least, but I was unaware that the starter would get hot, I will try to find the parts, thanks again:)
Ayuh,.........
I've Never seen a boat with a SBC that was running at 24 Volts......
Are you Sure it's in Series,+ Not Parallel,..??
firehog6305
The batteries are wired inline (parallel) I'm guessing, I dont know anything about 24volt, but I looked up 24volts on another form, and they arent wired up for 24volts, thanks for the help guys on the volt issue, and be safe out there on the 4th:)
