It's only a 7' stringer. Being my first time using that REALLY EXPENSIVE epoxy and filler I mixed up about ten pumps of resin and hardner and filler material, 3 times.(total of 30 pumps). Once the peanut butter took hold, there were a few places that it wasn't quite thick enough.
The boat as it came from the factory, and using the original stringers as templates, had a solid 3/4" of space between the hull and stringer. The stringer I made fit perfectly in the original position. After I placed the stringer before epoxy, I made note of how much of a gap there was. Now...here's where I made my mistake...
After letting the peanut butter set with the stringer, and squished out enough to make a fillet and bed the stringer, there were still some voids. Being the inexperienced epoxy man I am, I thought "hey! I'll mix up more epoxy, and then, the thicker peanut butter will hold it in place if I apply it on the high side of the hull. It'll just seep into the voids!!" Well...it worked for about ten seconds...then dilutes the peanut butter allowing it to ooooze down toward the keel.
I made a valiant effort laying it back up in its semi liquid state...and put heat lamps on it to help it harden. I achieved a fifty percent success rate...which mean a zero percent success rate. So...back to the hull I go an I'm going to thicken my replacement stringer so there isn't as much of a gap. Please don't ridicule me
. I knew I wouldn't get it right my first go 'round! But I will the second time!
