New canvas snaps are loose?
a70eliminator
I just installed a couple snaps on my newly taylored bow cover.
My plier type setting tool came with 4 snaps so I experimented by putting them in the 4 corners of my cover, the snaps are loose, they will pop off with very little tesion, it's like one corner pops off before I can get the opposite side snaped.
The snaps that came with the pliers are definately not getting it.
Is there a specific style I should be looking for, something with a little more grab, heck the ones on my mooring cover are tough to snap, these ones I used today don't realy go together with that pronounced "snap" feel, they just generally feel very weak.
Has anyone else experienced weak or loose snaps.
Re: New canvas snaps are loose?
Ayuh,... For All of 'em,... Check for Roundness,...
Sometimes you can "Adjust" them slightly with a pair of Plyers...
For the Sticky 1s,... Rub 'em with beeswax,...
The new 1s,... Do they look "Of Quality",..??
These guys are My favorite Suppliers...
I went to the Twist-lock style on some of the more Stressed points on my top/ curtains...
Once ya get beyond the co$t of the cutting die,... They're Great...
Fireman431
As an upholsterer, there is one other thing you can try. It sounds like you are using the proper setting tool (looks like a C-clamp with vise grip handles). Simply adjust the nut on the bottom of the handle 2 turns inward. Since this tightens the mandrel bend inside the snap cap, it slightly alters the width of the cap. This will give you a little more 'snap' when placing the caps.
Start with a half turn at a time until you get the proper feel. If you over do it, simply cut the snap cap off with a pair of side cutters.
kenmyfam
From what I have found when replacing them the secret is in the application. Experiment till you get the "feel" when applying them.
