New Carb
blazer
Have corrosion in my 86 Mercarb on a 181 C.I. 140HP 4cyl. motor. On another thread it was suggested I replace the carb with an "upgrade." Can anyone suggest a carb that I can bolt onto this motor that is better than the standard Mercarb? Where's the best place to get these marine carbs? Thanks
John_S
Re: New Carb
They probably assumed you had a SBC and not the 3.0L. For the 3.0L, might as well stay stock.
Re: New Carb
Ayuh,....... In your Other Thread,..... You never said What Motor you have, til After somebody mentioned it Might be a good idea to go to a 4bbl. Carb........
You've got the I4,+ the Factory Carb is about All that motor will Handle......
