LuvBoating
Thread starter- Joined
- Mar 16, 2009
- 718
Have a 1992 Celebrity 200 Cuddy Cabin w/5.7L I/O and 4 BL Quadri Jet Rochester carburetor. We bought this boat in April 2009 and the carb has been rebuilt twice, that we know of. Once, a few months before we bought it and then, right after we bought it. We were not informed of the "rebuild" when we bought it, so had it done after we bought it. During the "water test" of the boat, before buying it, we noticed that the engine kept stalling and were told, by the owner, that the carb needed some work and the cost of the boat would be reduced to compensate for the carb repair. We found out, by the marine mechanic, that the carb had already been rebuilt (he found out when tearing it down)........just a few months prior to us buying the boat.
Since then, we've had the carb adjusted (once) and another marine mechanic told us that it's adjusted as much as can be. I've sprayed the outside/linkage with Gunk Carb/Choke Cleaner and it seems to be ok, BUT, it is hard to start (a lot of pumping of the throttle) and the choke doesn't seem to work.
The Marine Service we use told us that there is no "after-market" carb available for this boat/engine, so we'd have to buy a brand new one. Since a couple of years ago, we had a new "bottom end" part of the engine put in, along with new plugs, wires, alternator and belts, a new carb/choke would probably be a perfect for this engine. Right? The new one will cost $777, plus $200 for putting it on. Wouldn't a new carb/choke help the engine to start much, much better.
Please advise. Thanks..
