New cdi and still no spark 1972 chrysler 85hp
Davidsjr
Bought a new cdi for my boat thinking that it was bad. I have bought new spark plugs and still no spark. Maybe the wrong cdi module? This is the one i purchased. And for some reason it didnt come with coil wire as shown
Nordin
Check the points gap, Clean and reset the poitns to 014 in.
The 1972 85Hp should be equipped with a points distributer but it could be replaced with a electronic one with preamp.
You can check for spark by setting the #1 (top) cyl. in TDC. Throttle at idle and then the curve at the disterbuter pully should line up with the flywheel rim.
Loose the white/black wire at distributer, turn on the ignition and strike the wire to ground. Each time you strike it the #1 sparkplug should spark.
