trucknutz36582
Thread starter- Joined
- Aug 11, 2013
- 41
Hi -
I've decided to replace ALL the wiring in my 2003 Stingray MS 200 but i am not sure what to get
and have not had any luck searching for it. I will try to supply all the details, and I apologize if I ramble in the process.
It's a 2003 boat, currently with a factory new 4.3 engine ( SN 1A657529 )purchased last year.
When I saw a build date of 2011 I freaked out - However Mercury sales told me it was one of the last 4.3s that was built with a new block.
short version:
Can you tell me what part numbers I need to order to completely replace the existing wiring harness on the boat side?
Other details
the engine was purchased brand new last year and has all factory wiring intact,
but the mechanic moved the closed cooling system and its hoses from the old - 2003 4.3 engine to this new one.
a couple of sensors are not plugged in - including the coolant temp on top of the engine.
The vendor supplied the 10-14 pin harness adapter and the mechanic hooked it up to the old harness.
since the engine had been in storage for a year after it was purchased, and had a build date of 2011,
the mechanic removed the distributor and used an adapter tool to turn over the oil pump with a drill, so there is oil in all of
the galleys and the heads.
when I turn the key briefly the motor cranks over.
I leave it in the on position, but nothing shows on the SmartCraft gauge.
I have not connected the fuel yet - i dont want to start a brand new motor without having a way of seeing the oil pressure.
The Smartcraft gauge is an SC1000.
the extension cable is the blue smartcraft cable marked "resistor on this end" - on both ends.
I have tried it with and without the junction box
with and without an external terminator plug.
The Smart-Craft gauge does not display anything when the key is turned on - the volt meter moves from zero to 12, so the dash is getting voltage.
the SC 1000 back-light button does not do anything, so its not getting power at every pin
- is there a troubleshooting guide that show the proper voltage on each pin on the purple connectors?
I removed the yellow terminator on the port side front of the engine and plugged in there.
- is that the correct place to plug in? I could not see any other compatible connectors besides that one.
I have tried the left battery, the right , and both settings on the selector switch. Bilge pumps and lights operate normally, and
the engine does turn over. - I only turn it over a revolution or two to confirm that the starter is seeing the full amount of
voltage.
Wiring is 3- ought , so we are seeing the full 13.4 volts at the starter.
I have not added fuel yet - if the engine does not pump fuel and raise the pressure up to the injectors, will it not activate
the SC gauge?
I assume there are some safety interlocks as far as fuel pressure, oil pressure, and water temperature go , but I don't know what is absolutely required just to be able to "see" the ECU status on the gauge.
Parts used - are they correct?:
Mercury Smartcraft 878492K14 Boat Gauge Junction Box Kit
Mercury Mercruiser Quicksilver Oem Part # 84-879982B20 Harness-Bulk
Mercury Mercruiser Quicksilver Oem Part # 859318B 1 Terminator
this is to connect to Mercruiser 4.3 ECT serial number 1A657529
My theory is the old harness has a break somewhere, or too much resistance , or that the shop that
had my boat for 6 months without finishing it made some mistakes.
Its messy and complicated to rehab the old wiring, and I have had no luck finding a new shop in my area
so I am looking for a "plug and play solution" so I can get back on the water.
I would rather buy a new harness than pay for many hours of shop labor to trace and repair the old one.
ot to mention I prefer the simplicity of having everything of the same vintage - rather than mixing old and new.
in the last year I
had a shop repair the transom with new core
have replaced (with new)
engine serial number 1A657529
transom assembly (Mercury)
outdrive (SEI)
trim pump
batteries
perko battery selector switch
000 wires made by GenuineDealz.com
steering assembly and cables
hoses for power steering
steering ram
axles and springs on trailer
full set of new rims and tires
Now it needs new wiring - and yet another cleaning
Thanks in advance for your advice - you guys rock!
short version:
Other details
voltage.
the SC gauge?
in the last year I
outdrive (SEI)
trim pump
batteries
steering ram
