New drive, should I replace water pump?
jcupo6
I bought a brand new SEI outdrive last September and only had the boat out twice after installation. Would it be best to replace the pump now, or should I wait and replace after a couple trips into the season? I was planning on just replacing it now, but was told by a friend it would be a waste.
JaseBosto
Re: New drive, should I replace water pump?
If its new, with a few uses on it, I would wait till the end of the season at the earliest and do it at winterization.
Rocky_Road
Your friend is looking out for you...if you need to replace your impeller every 4-5 trips, you are in for a long and tedious boating life!
Watch your gauges, and go have some serious fun.
Happy boating!
nola mike
and it has a 3 yr warranty anyway, right? :)
Don S
Warranty does not cover impellers.
Every other year is best case for being safe, not every 6 months.
Unless you have run it dry or have a problem, run it and stop worrying.
jcupo6
Thanks guys, I will not be changing it. I appreciate the help!
