little joee
Thread starter- Joined
- Dec 31, 2010
- 15
A quick question for the the gear heads. Do I need to adjust my new engine to the original engine's timing?
Background:
The original engine in my boat was timed at 1 degree BTDC, this engine freeze cracked last year and I replaced it with a new factory engine. The new engine came with a distributor and is timed at 2 degrees ATDC. I've kept the engine at that timing as the repair manual also specifies the same timing for engines with later serial numbers.
The engine runs excellent at this timing, but I want to be sure it's running at it's best!
Background:
