Jim Hawkins
- Joined
- Mar 11, 2013
- 508
First, I know it's under warranty but my problem is now intermittent and probably not the motor I don't want to waste time if I'm told it worked fine in the shop.
So, new F70 running along on plane suddenly shuts off. Restarted fine (back in neutral) but as soon as I put it in forward it cuts off. Restarting and putting it in reverse worked fine. Moving the shift lever forward after disengaging the shift reved the motor like normal. The motor cutting out coincided with my gps also turning off, as if something shorted the electrical system.Checking under the hood in the proximity of the shift cable I found a switch with two blue wires. Immediately after cutting off, and with the ignition still on I noted a wisp of smoke from this area and smell of burnt electric.
My best guess is that inside my control box a wire or switch is shorting out, killing the motor and that the smoke at the motor switch is a symptom of a control box problem and not the problem itself.
I have pulled the control box from the console and thats where I am now.
Also, disconnecting the shift cable at the motor and shifting to forward manually worked fine.
Any input what to look for and where? I don't know my way around the innards of the control box.
