new fleetwin question
54fleetwin
All right guys, I took the motor out w/o the pull start, I started it the old fashion way. Motor ran great. Pushed my 12 footer along at 9 mph.
High speed needle seemed loose.
does this speed seem correct?
bktheking
Re: new fleetwin question
Are you sure the water was high enough in the barrel?
54fleetwin
How do I know I have the right prop?
F_R
Tighten the packing nut on the high speed needle so it will stay put. There is a world of difference in boats/speeds. Try experimenting with different weight distribution, etc. OMC did a pretty good job of fitting their small motors with props that are good for the average boats the motor was likely to be used on. Anything else would probably be hard to find anyway.
54fleetwin
F_R
The packing was beyond tightening. lol
I picked up a carb rebuild kit for $14 shipped
Rebuilt the carb, took the boat out by myself, transferred as much weight forward as I could. I would guess she runs about 12mph, appears to be 3 times walking speed when looking at people walking down the beach.
No matter what I do, I can not get fully on plane with just myself in the boat.
I have resorted to kneeling on the floor between the last and middle bench to get more weight forward for any speed and more effeicient running.
I have to say, I have been a motorcycle nut for all my life. I love the old 2 strokes. I am quite surprised at the technology used on these old outboards.
They are way more advanced than most early 70's 2 stroke bikes.
lindy46
I usually put the gas tank as far forward as possible, and then I have to shift my weight toward the middle of the boat to get it to plane (same combo-Fleetwin on 12' boat). What notch do you have the tilt set? If it's on the third or fourth notch, try the second notch.
54fleetwin
My transom slopes from the top, forward at the bottom.
So I have been using the lowest setting. This kept the cavitation plate parrellel to the bottom of the boat. I shimmed the transom clamp with a piece of brass last night, this will allow me to have some adjustment now.
Now the motor can be adjusted some to help push the front down.
I haven't tried it yet.
54fleetwin
F_R
My 7.5 Fleetwin pushes my 14' flat bottom jon boat at 15.5 mph, GPS. You aren't going to get much better than 9 unless you can get it up on plane. Possibly just not enough horses.
54fleetwin
Well I can't really complain, boat was free from an old neighbor.
Motor and trailer free from my dad.
I replaced all the wood on the boat and did some work to the engine (carb rebuild kit, l/u seal kit, plugs, pullstart housing and coils.
Will look into the prop today to try to make sure it is the 7.5 prop and not a 5.5
