New here. Restoring a 1986 Fourwinns 160 freedom
Hunter404
What color to go with? i like both but i like to be different! don't mind the stitching still practicing first time using a sewing machine today. going with the same gray and blue that was int the boat. i had lime green thread in the machine and i kinda liked it.,
solar7647
I like the green as well.
Hunter404
i need to fiberglass my dog house. What should i use and where should i get it?
Boat took back burner for a couple weeks while i caught up on all my other projects.
Hunter404
US Composits in florida is about the best deal. I covered mine with 1708. [/QUOTEThank you i will look into that. hoping to have 75% of the interior dome by the end of the week.
not sure how to attach the bow back rest yet i want to sew everything together but it looks like they did not so they could use screws.
chevymaher
Screws through it all into the fiberglass. On the side ones. Originally one came from behind into the wood. I just added another one going from the front side. They screw in between the pads. Then once they tight the vynal will pop over the screw head most of the time.
Ones on the windshield side got 2 studs a piece on them. They go in the holes. One you access under the dash on port side. The other side I got to through the glove box.
The forward most one I put bolts through the wood before I put the padding and vynal. I used the wall anchors in the glass. It slides into that. I used a little gorilla glue in them and popped it on.
Hunter404
Well got the carpet in yesterday finished up the side panel going to finish cleaning up the wiring. then i will be on hold again waiting on parts. They have been Stuck in St.Paul due to all the riots they closed the post office there and my packages are in it. I was really hoping to have most the interior done this weekend. Also was going to pick up my block and head from the machine shop but he has not been able to finish it do to the riots he has been guarding his house in Minneapolis.
I live about 45 min north of everything going on and they still closed stores up here.
Can all this covid and riots just stop and lets get back to the new normal. IMG_1871.jpg
