New impeller but now no cooling
Well...thar explains it... lol....that's a simple fix...been there...done that.
did you run the pump dry?
should always use muffs with the hose on full. also need to make sure you have the bottom pickup hole blocked if its an AQ drive.
bmac417
Well that was the plan until I forgot to open the hose valve before I jumped in the boat to fire it up.
would like to say that has never happened to me......
as I sat there in the boat looking for water out the exhaust only to realize there was no water coming out of the hose.....
I have the same issue. There's water exiting the drive. when hooked to a hose bib. If I start it still no water out the exhaust prop port area. after first time out after winterized it over heated. I've checked the hoses 3 times there right I think once they were crossed at the pump changed impeller bearing and seals thermostat and hosed to thermostat housing took housing soaked it in Miratec acid and water boiled it out and wire wheeled it clean. someone said exhaust flappers are stuck possibly. Some say dont replace them say say you need them?
