new impeller kit
rbh
Does anyone use a dab of vaseline/grease to help role the new impeller into the new cup???
thanks
Rob
Bifflefan
Re: new impeller kit
I used 2-4-C the last time, but it was close and handy.
The big V should be fine too.
Rscardina
some may..but you dont want anything clogging the primer indent that allows the pump to keep its prime.. this is the small slot on the housing that the impeller housing slides into..
I use a very light weight oils..same oil as you would use for a pnuematic nailer.. or something similar...
Fishermark
Vaseline and other petroleum products can harm the rubber - I use dish soap.
stonyloam
From the "book":
"Lightly Iubricate water pump body insert with
2-4-C Marine Lubricant with Teflon".
