New leak UGH
rbh
1985 Merc 260, MR leg
So there is no water issues with the bellows I replaced, But there is a new leak and I believe it is coming from the Y pipe were it bolts to the inside transom plate.
Is this a common thing and easly fixed??
How often does the O-ring go or What could of happend
( I do realize the motor has to come out)
Thanks
Rob
cr2k
Re: New leak UGH
2 types of leaks I have seen at the Y pipe...
1..Loose bolts
2..Flapper pin fell down and vibrated long enough to wear a hole in the aluminum Y pipe.
Or is it coming form the shift bellows?
rbh
Re: New leak UGH
As far as I can tell it is coming out of the bottom of the transom plate???
hoping/guessing not, but it is really hard to tell what the heck is happening down there,
anybody know any weee people that can fit in there????
rbh
Re: New leak UGH
Anyone else want to take a stab at this leaky issue, always like to get a couple of opinions.
Just like going to the doctor. :)
dubs283
Re: New leak UGH
get a mirror on a stick and use a flashlight
probably the only way yer gonna see down there
fairly easy to fix, four 3/8" 12 point bolts, remove y-pipe and replace o-ring
overheat can cause the o-ring to fail, bolts loosen up over time
