New lower outdrive. No water flow Alpha 1 gen 1
duster22
Just put in a new lower unit and the water is not flowing. The impeller is new and looks fine. If you seen my earlier post i hit a rock and messed the gears of the lower unit the upper gears looked fine by eye. Any suggestions what it could be?
thanks
Bt Doctur
Re: New lower outdrive. No water flow Alpha 1 gen 1
impeller keyway missing,
duster22
no but i pulled the lower AGAIN. i found the impeller was kind of on one side more then the rest. probly by an litte under half an inch.
Would this affect it enough to not even push any water?
im gonna change it again and see what happens tomorrow.
cr2k
Also make sure you get the water tube in the guide.
duster22
good point.
thanks
