new member looking for advice on two glastron 1983 ssv 176 boats.
Fishermen Steve
I've the opportunity to by a 1983 glastron 176 ssv for $2500 that is turn key. (Sez the currant owner) comes with a 1990 115hp mariner and a 1998 load right bunk trailer. Found it on CL and looks sharp and near mint condition.
the other is the same year boat with a decent trailer, and a 115hp mercury that has lost its spark for $1500.
my question is should I spend more money and get the turn key or save some money and get the one that needs a little engine work?
Steve
Frank Acampora
Stay away from the Mercury! It can easily cost the extra $1000 to get it running again--possibly more, and you have the fuss and bother of getting it repaired. NEVER-NEVER-NEVER buy an engine with a known problem that keeps it from running--unless you are very good at repairs or want to gamble and want to play with it a while!
You don't know the history of the engine other than what the "honest" seller tells you.
If you are looking to either carry a heavy load or more than 4-6 people, or want to water ski, either boat will be under-powered. If you want to tube and wakeboard, or fish with it then the 115 will do fine.
Incidentally, the boat in the avatar is a 15 foot Glastron with a 120 on it.
Fishermen Steve
Thank you for the advice Frank. I'll take a closer look at the other one.
Steve
pckeen
As usual, Frank's advice is golden. Do a water test, and check out the $2500 boat thoroughly.
Fishermen Steve
Here is a photo of the ssv 176 for $2500. Also includes life jackets, skis an or etc. Winter is a good time to buy here in New England now cuz there's so much snow know one wants to move anything around in so much snow!
pckeen
Can't tell much from the photograph - seems to look good. The good news with buying off season, is there are fewer people looking, so you have a better chance of getting a good price. The bad news is you can't water test it or run it on muffs. If you are going to buy now, check it very carefully, and ask for a written guarantee of no leaks and that the engine runs. Check for soft spots in the floor, and that the transom is completely solid with absolutely no flex (soft spots = a rotten structure, and flex in the transom = a transom replacement. Either one means you have a restoration project on your hands, and not a usable boat).
