Good morning, everyone, and thanks in advance for your help. I googled prop repair last night and found this forum; I'm amazed at the wealth of information and knowledge found here, and the willingness of members to help out fellow boaters. Very impressive!
I recently purchased a project boat - a 16' Starcraft deep-V w/1987 Mercury Classic Fifty outboard. The boat was rough and the outboard in need of service. It was thrown together by a dealer looking to dump it at a consignment auction, and the tech that did the work has since been fired (I spoke to the owner after finding numerous issues - but that's a whole nother story). After rebuilding the carbs, pump, lines, etc., and having my local dealer adjust all the linkages and timing, it runs well and moves the boat around on the Mississippi pretty well. However, the prop - which looks like it's almost new - has a couple dents on it that I'd like to address. I also noticed that the aluminum trim tab above the prop is broken off.
I've had the boat out on the water a couple times since getting everything back together/the outboard serviced and I've noticed a couple things. One, it's a pooch out of the hole. Two, while running at lower speeds (i.e. no-wake zones on the river, the outboard seems to shake/vibrate more than I would expect an inline 4 to do). I'm wondering if the prop is to possibly blame for both items.
The outboard was tilted up higher than it should have been (w/the limiter bolt/rod in the third hole from the bottom on the power tilt/trim unit), so I just dropped it down one hole (I probably butchered terminology there - sorry - but hopefully you follow what I'm referring to). The outboard now sits more parallel w/the boat in the fully trimmed down position. I'm hoping that this will help with getting the boat out of the water more quickly/planed out, and keep the engine from what I believe was ventilation, when turning sharp and/or going over other boats' wakes. The dents in the prop maybe were contributing as well to possible ventilation?
There are no chunks missing or burrs on the prop so I'm not sure if the prop can be out of balance by simply being bent in spots, but I'm hoping that might explain some of the low speed vibration seen. There's no water in the lube, so I don't think the shaft is bent.
Attached are a couple pics of the prop (along with one of how the outboard now sits being fully trimmed down). I'd like to bend the prop back myself, if possible. My questions pertaining to doing so are these:
1) Does the damage look ok, and within reason, to hammer back to shape?
2) I assume the prop must be removed to do so, but wanted to confirm.
3) I've seen references to using a ball peen hammer and also a rubber mallet (along with a block of wood); which is the better tool to use?
4) Should heat be used?
5) Lastly, what is the main function of the trim tab, and would it being broken cause any of the issues I'm seeing?
Thanks so much for your time and help; I really appreciate it!
