New member. New project
7mm
Hello, I am a new member and have just purchased a 1987 Starcraft Islander. I am just getting started replacing the decking and transom. I hope to be able to use the original 2.5 L OMC stern drive. She runs, shifts, and has decent compression. The hull and bottom are in good shape and is pretty much complete except the rear jump seats are missing. Does any body out there know what the XL stands for? The decals read Starcraft Islander XL. I don’t remember seeing that on other islanders that I looked at. I am also looking for ideas on building a engine cradle. I would like to be able to work on the motor and run it in the cradle. Thanks in advance for your help
jbcurt00
What length Islander?
Got pix?
Never heard/sen of an Islander XL
7mm
I am going to pull the engine out of the boat today but I noticed that there is only one lift point. It is on the starboard front. The book shows another lift point on the port rear but all I see is the exhaust manifold. Any ideas​
7mm
[No message]
you need to pull the drive prior to pulling the motor
set the motor on a pallet or a few pieces of wood if you want to run it outside the boat. no need to get fancy and build a "cradle".
heck an old tire under the oil pan would work too
7mm
Thanks Scott. I pulled the drive off yesterday. What do you think I should do about only having one lift point.
7mm
Islander XL ?
I just purchased a 1987 Starcraft Islander XL. It’s a 221. Does anyone know what the XL means or is the XL equipped differently than other islanders.
jbcurt00
7mm avoid duplicate topics
Merged w your original topic
Want it left in the Starcraft forum or over in the Resto forum I left the merged topic?
Watermann
Is that XL decal on each side? Looks like it was put on by a PO, SC never put an XL bird decal on any of their boats.
fetch
7mm
Thanks I was thinking the same thing. And yes it’s on both sides.
