2old-scuba-dude
- Joined
- Jun 10, 2011
- 2
Man I'm glad I found you guys. I just bought a 2000 21ft. Sun Tracker Party Barge. Got it home and heard water sloshing in Port pontoon. Stumbled upon your forum and learned a wealth of info on pontoon construction; leak testing; and probable sources of leaks. I had no idea pontoons had plugs on the top side of the pontoon (in part due to the fact that Sun Tracker went to great lengths to HIDE the things under the deck mounting brackets where no human arm can reach). Thanks to you guys I discovered that mine had two plastic pipe plugs on top of each pontoon. I found the front plug on the affected pontoon was broken off flush w/ the toon. The plastic plug threads were still in the hole, but I could insert a small stick into the hole so I figure water was splashing into the hole. I then attempted to remove the rear top plug using an open end wrench and the square head snapped off from the plug leaving it in the same condition as the front.
Now I have three questions and one assumption. My assumption is that my pontoon is multi-chambered and air tight because when I broke the back plug; it hissed out pressurized air for approximately 3 or 4 seconds (even though the front was open). QUESTION #1. Do you think these red plastic pipe plugs were Sun Tracker equipment. I ask because I saw on your forum that these plugs are supposed to come with pressure relief hole in them. QUESTION #2. Will the absence of relief holes cause enough pressure to explode them (or implode them depending on the direction of temperature change). QUESTION #3. Can somebody please tell me how to get these broken plugs out without drilling a fist size hole in the deck above them?
I'm hoping that the water in the toons came from the open plug. If I can get them out and replaced I can put it in the lake and see if the water returns. Sorry for the long post, but I'd really like to get this thing in the water at least once this summer. Thanks for being here.
