jaybrassmonkey
Thread starter- Joined
- Feb 19, 2015
- 74
About to order a reman motor from Rapido. Have seen more positive reviews than negative, just gonna hope for the best. But wanted to run this all past you guys, please look for red flags. Long story short is that Ithought I had a cracked block. In dismantling the motor I'm not seeing any cracks. Head gaskets were great, heads were great, can't see inside the block but dont see any cracks in the cylinder walls or in the intake valley. I suspect water was getting in through the exhaust manifolds, they are the single piece ones, lots of rust where it shouldn't be. BUT, I've got the money squared away and I've gone this far so gonna go ahead and swap it.
I'm going to order the long block. I'm going to use the old water pump, the old oil pan, power steering pump and alternator. The starter was just rebuilt and has a warranty. All the hoses look to be in good shape. Even the drive coupler looks good, from what I can see with the outdrive off. Haven't pulled the motor just yet but gonna check the flywheel too. The carb was just adjusted so I'll use it. And the distributor looked good and has a new button and cap with plugs and wires, all re-useable. Will be getting a new timing chain cover with new motor. Going to order Sierra exhaust from wholesale marine. Gotta get the manifold, riser and elbow with bellows to convert. New temp send and temp alarm and thermostat. New oil pressure send and alarm. There was this other thing that looks like some kind of send unit at the back of the intake on top, near the distributor (?). Fuel pump=reusable. Resistor=reusable. Thermostat housing is questionable. Lots of corrosion inside, has been dry so rust color is there, not sure on replacing but running out of money.
Gonna clean the bilge real good, wire tie and loom everythign that's dangling. Oh and 1 new battery.
Anything y'all recommend?
