I recenlty got a new boat with new Yamaha F250. Motor has just over 2 hours on it. Time and RPM according to the break in schedule. Never been to WOT, just a short cruise in Coinjock canal to get over the 2 hour mark.
Anyway, after installing Blue Sea System Batt switch and auto charge relay, I started the motor on muffs and hose to make sure charging system was doing like it was supposed to. Looked good, charging relay and batteries appeared to be doing what they were supposed to do. Motor ran maybe 3 minutes on the muffs, water never came out the telltale. This evening I wanted to check it again, put the muffs on, water going, turn on the ignition and get the warning buzzer and Water in Fuel warning from the Command link tach. I remove the fuel separator with the sensor from the engine, empty it, dry it and replace it. Warning returns. Unplug the sensor, buzzer still sounds, warning still blinks. Pushing set or mode stops the buzzer, but visual warning still blinks.
New boat, new motor, so I don't know how long it sat on a lot with little or no fuel in it. The water separating fuel filter looks new and undamaged. Do I replace that next and see what happens??
Any help will be appreciated.
david
david
