Re: New motors vs Old motors
In real life, the guys going from carbed two strokes to 4 stroke or even DFI 2 strokes are looking at 30-40% increase in fuel efficiency. At least in the High HP motors we use.
Yes, he's right! (of course
even on smaller motors.
My previous 40hp 1964 Johnson would use a 6 gal tank in a 1/2 day fishing. The newer (yet still old) '85 Suzuki will go all day trolling and still have enough to get back to the ramp. Plus, with the oil injection, my oil consumption has been cut to about a third of the mix-every-tank Johnson. The new EFI/DFI has got to be fantastic compared to mid-80s carbureted motors, too. Speedwise on my trusty Niagara: old Johnson, 27-28mph, newer Suzuki, 33-34 mph GPS with the same empty boat.
Another point, the power on the newer engine - the advertised Horsepower is rated at the prop. Force, if I remember correctly, was rated the old way: at the powerhead. Reduce the label-rating on a powerhead-rated boat motor by about 15-17% to guestimate prop HP. A 50hp Force is also heavy yet performs like a strong 40hp.
Example: 2008 season my buddy switched his 1988 85hp Force to a 1989? 85hp Johnson. Both props had the same pitch. Fuel consumption went down, which was good. But most importantly, his top speed (19' boat) went from 26mph GPS to almost 34mph GPS.
puddle jumper says: "
A good example say my 89 force 50hp vs a 2010 merc 50hp. Both are 50hp but would the power out put be that diffrent?"
The answer is that a 2010 2-stroke Merc/Yammi or Evinrude/whatever will be more fuel efficient at
all speeds, and will also improve your top speed while still using less fuel. If the difference is as substantial as the two examples I related and you have the jingle for a new motor, the switch would be a hands-down improvement. IMHO
