GaJeff
- Joined
- Jul 9, 2012
- 149
Hi all... I have an 81 Citation 19ft. With 120Mercruiser 4cyl. Alpha1 outdrive. Just installed a manual oil pressure gauge on the engine. Now it won't start. It will catch for just a sec and die before it kicks up. The old gauge had an electric sending unit screwed into the side of the block with a blue or purple wire on it. I took it off and installed a 1/4" compression fitting on it and ran a line from it to the gauge. Hooked up my ground and light. The other gauge is fully electric with ground, pos, and a sender wire going to it. The wire at the sender goes into a harness and up to the dash.
Is it possible that with no signal from the sending unit the engine will not run? Can I bypass this to run my manual gauge? Or is changing out the gauges no problem and I have some other issue? I have ran the boat everyday this week and no problems at all. So I know it runs but maybe something else has happened.
Any help is appreciated in advance
Jeff
Jeff
