USA_boater
- Joined
- Jul 31, 2018
- 277
Got an '04 Four Winns from a cousin who apparently didn't do very good maintenance. Boat in great shape appearance-wise, but sat for 5yrs un-used in covered storage. The water had been drained from the block/exhaust but that's about it. I sprayed seafoam deep creep into the cylinders before turning the motor over just to be sure they were not seized up.
So far I've changed the fuel filter, oil & filter, and poured 2 cans of seafoam in the gas tank and topped it off with fresh non-ethanol premium unleaded, got fresh batteries (has a dual bat switch), greased gimbal bearing zerk, topped off power steering fluid (with regular automotive fluid, hope that's okay?). He told me he changed the lower unit oil before he put it away in 2013. I confirmed it was full/clean and he gave me a left-over bottle of 75w90 Castrol gear oil; I'll probably change it out at the end of this season anyway.
I then ran it on the trailer to be sure it didn't overheat before taking it out. I've had it out for testing twice so far. The first time it ran just above half on the temp gauge and I didn't idle much. The second time out, a friend of mine who is a boat owner came out and was harder on it and we also idled much more. It heated up to over 3/4 of the gauge after running hard and then idling. He said I should change the impeller (which I'd already planned to do). However, I am also wondering if there could be rust clogging up a cooling port or even the thermostat since this thing sat for 5 yrs without being properly winterized.
The tach doesn't work and the fuel gauge works but is way inaccurate so we didn't rule out the possibility that the temp gauge may be lying too? I have a laser temp gun, would that tell me if I read the head temp while it was idling?
So now that all that background is taken care of here are my other questions:
- Can I use a regular cap/rotor for a 4.3 chevy or is there something special about marine?
- Also, same question about plug wires
- Plugs appeared to be GM platiums, can I cross those to NGK and run NGK instead?
- The drain plug is corroded in place and I've tried everything to get it loose, I think I am gonna have to replace the entire drain plug & housing...if so, where can I get one and what kind of epoxy/sealant do I use for it?
- When winterizing do you even need to drain the water from the motor if you are going to suck up the pink antifreeze method?
- What should I look for why the tach is dead?
- How do I know whether I have the fresh or sea cooling so I can get the correct thermostat?
- Is there ANY locally available trim fluid I can use or must I order the volvo to top off the trim fluid reservoir?
- Does the power steering pump take the same stuff as the trim?
- The motor sticker doesn't show anything that indicates what version of the 4.3GL this might be. How can I tell? I assume since boat made in 2003 and is a 2004 model year must be either a "C" or "D"?
- Why no "trailer-up" button on this boat? Where should trim needle be when loading/unloading...I've been careful not to start boat with trim all the way up
- Is Rotella T5 15w40 CK-4 oil okay for this flat-tappet boat engine? I almost added some STP or something to give it more ZDDP but I saw a VOA that said the rotell still had > 1000 on zinc/phosphorus levels.
I'm sure I will have more questions but this is enough to break the ice...thanks guys!!!
