So troubleshooting a leaking carb, i decide to take a compression test, and find the #3 hole is only 35lbs, take off head and find this:
The rest of the cyl all have 130-140 psi so i am hopefully just going to have to replace the piston and hone the cyl. The scoring is not too bad, barely can catch a fingernail on it. I am going to break it down and bring it to a machine shop to make sure all the holes are round and the scoring isn't too deep.
This'll be my first rebuild of anything bigger than a 2cyl...
I have a few questions, how should i remove the powerhead? Is it liftable by 2 people? I am going to remove carbs, heads, and flywheel to reduce weight a bit. I was thinking about using my garage rafters to fashion a pull style lift. The garage is a 2 car, has decent support, but i don't want to pull down any rafters on my head! Any suggestions from those who have rebuilt one of these v4 crossflows?
Should i re-ring the rest of the pistons? The compression is so good i'm leaning towards no.
Thanks for the help, this forum has been awesome and I have learned quite a bit.
