New piston rings
demarko210
I installed new piston and rings in my Mercury 110 now when I try to turn the flywheel it's very difficult and almost ripped the pull starter out. Can anyone help and tell me where to look it's a Mercury 110 serial number 318 XXX thanks guys
did you file the rings to fit? clean the ring grooves? deglaze the bores?
are these over-sized rings in a standard bore?
Are pistons oriented the correct way.-----Is crankshaft properly seated.------Is lower unit free to turn ?
demarko210
I cleaned the postion didn't remove from rod or crank. I hone cyclinder using fogging and 2 stroke. New upper seal
demarko210
Lower unit turns piston ring align with the groove. The main has a pin hole that lock the crank in position with the reed
tpenfield
If you take out the spark plugs, doe the engine turn freely or does it bind a bit?
I recently did similar work on my Merc 7.5 and found that during the re-assembly the lower bearing was not fully seated and was causing the crankshaft to bind up.
See if the engine spins freely without the spark plugs.
