Re: new points
View points as nothing more then a mechanical switch, because that IS all they really are. And what usually makes points pit or burn, is a current flowing through them. They tend to spark when opening and that IS what the condenser's job is. It is parallel to the points to help eliminate that spark by storing up the current right when they start to open. The condenser is basically shorted out while the point are in their closed position. When the points just start to open, which is also the time a spark would occur, the condenser take the charge of the current and as the points continue to open the spark opportune is removed and the coil comes in to play in the circuit. Really a very neat little circuit that works amazingly well...
